FIBERGLASS COATING
  • FIBERGLASS COATING
    Posted by william on 27/11/2021 at 2:52 pm
    Hi Expert,
    Is it possible to do UT thickness measurement on fiberglass coated plate ? Below are the details. Thanks in advance.
    1. Material : Carbon Steel
    2. Coating : Fiberglass up to 1mm
    3. Plate thickness : 10mm
    jaden replied 4 years, 4 months ago 2 Members · 1 Reply
  • Coating Inspection
    jaden
    28/11/2021 at 12:34 pm
    Yes.
    Standard Coating Thickness gauges will measure the fiberglass thickness.
    Assuming the fiberglass is properly stuck to the steel an is ‘nothing weird’ then multimode (echo-echo) ultrasonic thickness gauges (not the cheaper single echo only) will give accurate readings.
    For poorly adhering or sound insulating coatings then pulsed eddy current should work, but that is much more complex/ expensive.
