Minumum depht of a discontinuaty to be detected by dye penetrant testing
  • Minumum depht of a discontinuaty to be detected by dye penetrant testing
    Posted by arsal on 27/11/2021 at 2:04 pm
    Hello,
    please tell, which is the minumum depht
    (in microns) of a discontinuaty in steel to be detected by dye penetrant testing?
    I see (without a magnifying glassa) a crack (length is 5 mm) on perfectly cleaned tested surface, but using of dye penetrant testing does not give an indication. I understand, that it is a surface crack and want to know what is the minimum depht of a discontinuaty to be detected by dye penetrant testing.
    lucas replied 4 years, 3 months ago 2 Members · 1 Reply
  • Dye Penetrant Inspection (PT) (DPI)
    lucas
    27/11/2021 at 10:16 pm
    Penetrant Testing is not meant to establish the depth of a defect that is open to the surface. If you really want to know the depth of a surface indication, I recommend using Eddy Current or Ultrasonic Inspection.
