Failure Mechanisms
Public Failure Mechanisms
Active 11 months ago
Welcome to [NDT Inspection Portal]’s failure mechanism group, a place for professionals to connect... View more
Welcome to [NDT Inspection Portal]’s failure mechanism group, a place for professionals to connect and discuss the latest techniques and technologies in the study of failure mechanisms. The study of failure mechanisms is an important aspect of ensuring the safety, reliability, and performance of products, materials, and structures in various industries. It involves the analysis of how and why a component or system fails under various conditions and the identification of the underlying causes of failure.
Failure mechanisms can be complex and can involve a range of factors, including material properties, design, manufacturing processes, environmental conditions, and operating conditions. The study of failure mechanisms involves the use of various methods and techniques, including mechanical testing, metallurgical analysis, and computer modeling, to evaluate the performance and behavior of a component or system under different loads and conditions.
Our member group offers a platform for sharing knowledge and best practices on the study of failure mechanisms and its applications in various industries. Join our community of experts from around the world and be a part of the conversation on advancing the understanding of failure mechanisms and improving the performance and reliability of products, materials, and structures. Whether you are new to the study of failure mechanisms or an experienced professional, you’ll find valuable resources and a welcoming community in our group.
Problems with electromagnetic fields
Posted by leo on 27/11/2021 at 7:46 pmDear friends
I’m carrying out some UT immersion test on a aluminium wheel driven by an electric motor.
Unfortunately the signal is very disturbed by “spikes” generated by the motor. Any suggestion in order to reduce (or eliminate) this problem?
Thanks in advancecaleb-charles replied 4 years, 9 months ago 2 Members · 1 Reply- 1 Reply
Simple things to try
1. Move or Shield the power to the motor – make sure the motor wires are not less than 10cm from the probe connections. Check grounding etc. – Thry linking the probe body to the motor case. If its already joined try disconnecting it (These things are seldom rational until you’ve solved them)
2. Put some capacitors across the motor contacts – 0.1 uF low impedance type should reduce most spikes. Wrap the power leads round a toroid or use series inductors
3. Move the motor – Drive the mechanism via a belt and pulleys (Usually necessary anyway to keep the motor out of the water)
4. Make Sure the motor power supply is not contributing – Some switched mode power supplies can kick out a lot of noise.- Do you get spikes when the voltage is reduced and the motor not turning? If so its not the motor…
Good luck
