Remote visual inspection
  • Remote visual inspection
    Posted by NDT-Inspect on 12/12/2022 at 1:51 pm
    Remote visual inspection (RVI) is a non-destructive testing technique that is used to examine the internal and external surfaces of a variety of objects and structures. RVI involves the use of specialized equipment, such as borescopes and fiberscopes, to visually inspect the surface of an object without physically touching it.
    RVI is commonly used in a wide range of industries, including manufacturing, aerospace, and petrochemical. It is a valuable tool for identifying potential issues and defects in materials and components, such as cracks, corrosion, or other damage. RVI can also be used to verify the quality and integrity of an object, such as to ensure that it meets the specified design specifications.
    One of the key advantages of RVI is that it allows for the inspection of objects and structures that may be difficult or impossible to access using traditional methods. This can include objects that are located in tight or confined spaces, objects that are too large or heavy to be moved, or objects that are located in hazardous or challenging environments.
    RVI is typically performed by trained and certified inspectors who have experience with the specialized equipment and techniques used in RVI. The inspection process typically involves the use of a borescope or fiberscope to visually examine the surface of the object, with the inspector carefully observing the images or video captured by the RVI equipment to identify any potential issues or defects.
    Overall, remote visual inspection is a valuable tool for identifying potential issues and defects in materials and components, as well as for verifying the quality and integrity of objects and structures. By allowing for the inspection of objects and structures that may be difficult or impossible to access using traditional methods, RVI can help to ensure the safe and reliable operation of critical equipment and systems.
    NDT-Inspect replied 3 years, 3 months ago 1 Member · 0 Replies
