747 members · Public group
You were talking about the advantages of Pulse Compression. What are the drawbacks of the Pulse compression in comparison to normal excitation?
4 years ago
There are two main disadvantages;
1) It requires much more flexibility in the excitation hardware, ideally the signal source and/or amplifier needs to be able to generate arbitrary waveforms. This is not typically possible with conventional UT hardware (basic pulsers).
2) The received signal must also be post-processed (digitally) before it can be viewed. Although this is not such as huge disadvantage since this is also the case for many modern NDT methods (e.g. FMC TFM).
