What is minimum defect size Ultrasonic testing can detect?
  • What is minimum defect size Ultrasonic testing can detect?
    Posted by NDT-Inspect on 11/12/2022 at 7:25 am
    The minimum defect size that can be detected using ultrasonic testing depends on a number of factors, including the type of ultrasonic testing method used, the sensitivity of the equipment, the skill of the operator, and the type and condition of the material being tested. In general, ultrasonic testing is capable of detecting defects as small as 0.1 mm in diameter in metals, although smaller defects may be detectable in some cases.
    There are several different types of ultrasonic testing methods, each of which has its own capabilities and limitations. Some of the most commonly used ultrasonic testing methods include pulse-echo testing, through-transmission testing, and phased array ultrasonic testing (PAUT).
    Pulse-echo testing is the most basic and widely used ultrasonic testing method. It uses a single transducer to both transmit and receive ultrasonic energy, and it is capable of detecting defects that are located on the surface of the material or just below it. Pulse-echo testing can typically detect defects as small as 0.1 mm in diameter in metals.
    Through-transmission testing is a more advanced ultrasonic testing method that uses two transducers to transmit and receive ultrasonic energy. This method is capable of detecting defects that are located deeper within the material, and it can typically detect defects as small as 0.05 mm in diameter in metals.
    Phased array ultrasonic testing (PAUT) is a highly advanced ultrasonic testing method that uses multiple transducers to create focused beams of ultrasonic energy that can be electronically steered and scanned to inspect a specific area. PAUT is capable of detecting very small defects, and it can typically detect defects as small as 0.01 mm in diameter in metals.
    In addition to the type of ultrasonic testing method used, the minimum defect size that can be detected also depends on the sensitivity of the equipment, the skill of the operator, and the type and condition of the material being tested. Higher sensitivity equipment, skilled operators, and good material conditions can all improve the ability of ultrasonic testing to detect small defects.
    NDT-Inspect replied 3 years, 9 months ago 1 Member · 0 Replies
