ASME B31.3 ACCEPTANCE CRITERIA
  • ASME B31.3 ACCEPTANCE CRITERIA
    Posted by nde on 21/05/2021 at 6:41 am
    Dear All,
    Please refer below for ASME B31.3 acceptance criteria. To reject any indication i need to comply 3 rules :-
    1. It must be linear indication
    2. The indication level must be above reference level
    3. Comply with Rejectable length.
    If i never comply with one of the above criteria i cant reject any indcation. How about Lack of sidewall fusion , lack of penetration and crack which is consider as a serious indication? Do i still need to follow this 3 rules or can i reject this indication since its a serious indication? I am just concern about small thickness and please advice. I just found one lack of sidewall fusion which is :-
    Length :4mm
    Amplitude level : 50% DAC
    Material thickness : 5.49 ( 3″ sch 40)
    ASME B31.3-ACCEPTANCE CRITERIA
    344.6.2 Acceptance Criteria. A linear-type discontinuity
    is unacceptable if the amplitude of the indication
    exceeds the reference level and its length exceeds
    (a) 6 mm (1⁄4 in.) for Tw ≤ 19 mm (3⁄4 in.)
    (b) Tw/3 for 19 mm < Tw ≤ 57 mm (21⁄4 in.)
    (c) 19 mm for Tw > 57 mm
    chris replied 3 years, 5 months ago 2 Members · 2 Replies
  • 2 Replies
  • Codes and Standards
    chris
    21/05/2021 at 6:42 am
    First of all, where does it state in ASME B31.3 that an indication has to be linear to be rejected?
    If you have Lack of Fusion or a crack or Lack of Penetration, it is rejected anyway, regardless of length. If you don’t reject it, you’re not doing your job.
    chris
    19/11/2022 at 2:55 pm
    ASME B31.3 Acceptance Criteria
    344.6.2 Acceptance Criteria. Acceptance criteria
    shall be as described in (a) or (b).
    (a) A linear-type discontinuity is unacceptable if the amplitude of the indication exceeds the
    (1) 6 mm (1⁄4 in.) for Tw  19 mm (3⁄4 in.) (2) Tw/3 for 19 mm  Tw  57 mm (21⁄4 in.) (3) 19
    mm (3⁄4 in.) for Tw  57 mm (21⁄4 in.)
    (b) The fracture mechanics ultrasonic acceptance cri- teria in Appendix R may be used if all
    requirements of
    Appendix R are met.
