ZY-10 Micro Video Control Pipeline Crawler
  • ZY-10 Micro Video Control Pipeline Crawler
    Posted by luna on 13/10/2021 at 8:25 pm
    ZY-10 Micro-Wave Video X Ray Pipeline Crawler is used for check pipeline welding joint through micro-video system work with DC x ray unit which powered by battery pack on the pipeline crawler. Pipeline Crawler running in a wall or pipeline; detect internal defects and flaws through radiography technology, move steadily inside the pipe with speed of up to 18m/min and distance up to 5 kilometers .
    Features:
    1. Absolute Guarantee Operator Safety
    ● Positioning by wireless microwave video instead of original isotope positioning.
    ● The generator voltage can be adjusted according to different conditions, in order to meet the testing needs.
    2. Available for Different Diameter Pipeline
    ● Applying different pipeline diameters; forward speed 18m/min.
    3. Accurate Positioning
    ● Adopts advanced PLC control system to achieve more precise positioning.
    ● Real-time continuous show the pipe inner situation.e.g.: NDT Equipment fault, battery State LOW, over tempered inner pipeline, distance to the pipe mouth.
    4. Reliable Energy Supply
    ● Electronic speed control motor function, to achieve constant torque, constant current operation.
    ● Automatic inspect the energy .
    5. Ensure the Film Density
    ● X Ray Unit has regulatory function of KV with large diameter and thick walled tube has the regulatory function. Tran-illumination to ensure the X-ray film and degree of consensus.
    6. Full Set Security Protection
    ● Real-time function to protect the x ray unit from meeting water, over voltage, over current, x ray unit falling off, over temperature.
    ● Automatic stop function, with no need of Real -time monitoring.
    ● High quality sealed lead acid battery for prevent.
    ● Inspect the energy automatically, crawler will turn back in time when energy is lacking, so that to prevent losing the crawler in the pipeline.
    luna replied 4 years, 4 months ago 1 Member · 0 Replies
