AUT vs Crawlers for production on long gas lines
  • AUT vs Crawlers for production on long gas lines
    Posted by george on 27/11/2021 at 5:01 pm
    Could anyone help me with a couple of questions on AUT vs. Crawlers
    I am under the impression that the amount of repairs that might show up on an inspection of double wall pipe might be more with Crawlers than AUT. Is that correct, or am I wrong?
    I have heard that anamolies, or problems that would show up on crawlers might invoke more repairs. And not necessarily be problems, but would have to be repaired because of the type of procedure used for crawler is different for AUT. Any opinions?
    Would be greatly appreciated.
    charlie replied 4 years, 4 months ago 2 Members · 1 Reply
  • Pipeline X-Ray Inspection
    28/11/2021 at 2:11 pm
    AUT tends to focus more on the bevel sidewalls as compared to RT which wouldn’t miss a 3mm Pore that AUT at times might. Both the techniques have their own advantages and disadvantages and shouldn’t be compared. Both the techniques use API 1104 for evaluation again which are basically the same. I unfortunately haven’t had the chance to work with RT and I wouldn’t be able to answer all of your questions I’m sorry.
    I would recommend AUT when it comes to long pipelines, the primary reason being that if you’re running a semi automatic / automatic welding mainline setup, your biggest concern would be production in which case AUT would give you more real time results in the sense that the AUT crew would be just beyond the mainline most of the time. You can even have the welding crew informed beforehand as well for certain indications that keep repeating themselves at particular locations, the welders and the on site technician would be more than willing to fix it once you give them the depth, the location and the height and they figure out which pass it comes from. You can also have a repair crew run behind the AUT crew to fix the repairs immediately. Overall this kinda setup usually works out very well for everyone.
    I hope this helps.
